edde Опубликовано 26 апреля, 2010 Жалоба Поделиться Опубликовано 26 апреля, 2010 Для семерки неактуально в семерке не работает. есть варианты правки вручную системных файлов if you like to have a fixed background and text colour then you can modify your shellstyle.dll. do this solution only if it is very important [for your needs--> health neccecity, eyes etc as this is not the best solution] first save to a safe place your original microsoft shellstyle.dll , copy it from C:\Windows\Resources\Themes\Aero\Shell\NormalColor to a safe folder . then copy it again lets say to your desktop. Open your shellstyle.dll with freeware resource hacker ( http://www.angusj.com/resourcehacker/ ), select view , find text and writte : <if id="atom(clientviewhost)"> you will see this ----------------------------------- </if> <if id="atom(clientviewhost)"> <ViewHost foreground="windowtext" background="themeable(gtc(ItemsView, 0, 0, 3802), window)" sortcolumn="themeable(gtc(ItemsView, 0, 0, 3802), window)" subtext="ARGB(255, 139, 139, 139)" /> ------------------------------------------ the background parameter gives you the background color, if you like to have a fixed color then change this from: background="themeable(gtc(ItemsView, 0, 0, 3802), window)" to be background="themeable(ARGB(0, ---, ---, ---), window)" the --- is the rgb color you like. so i choose for you a colour[if you dont like find your favourite] so lets say a 216, 232, 242 so background will be as: background="themeable(ARGB(0, 216, 232, 242), window)" then replace the values to look like ----------------------------------- </if> <if id="atom(clientviewhost)"> <ViewHost foreground="windowtext" background="themeable(ARGB(0, 216, 232, 242), window)" sortcolumn="themeable(gtc(ItemsView, 0, 0, 3802), window)" subtext="ARGB(255, 139, 139, 139)" /> ------------------------------------------ then select again view , find next and again replace the <if id="atom(clientviewhost)"> as many times this exist. then select compile script, and save it. [ you can also change the text color to a fixed color changing the parameter foreground="windowtext" to a parameter like foreground="windowtext" to foreground="themeable(ARGB(255, 252, 252, 252), windowtext)" or foreground="themeable(ARGB(255, 128, 128, 128), windowtext)" or whatever color you like] after save it you replace your original shellstyle.dll from your C:\Windows\Resources\Themes\Aero\Shell\NormalColor if you use the aero theme as the source of your experiment. restart to see your changes. do that on your own risc. ------ if you have vista style builder[its a program http://www.vistastylebuilder.com/download.html that make visual styles also compatible with windows 7 its ease to change the background color --->if i remember well, it is the fil color on Explorer & Shell > Explorer > Items View > ItemsView ---------------- but if i want more there was the application for vista which i do nt know if it works on 7 or if its the same like that reffered [or if run on compatibility mode or non run anyway] , Vista Folder Background http://www.aveapps.com/folderbg.html i have also given my oppinion http://social.technet.microsoft.com/Forums...a8-ff0650105fb9 ,and asked if microsoft could make an application that controls the whole interface system , because this is the right solution, as there also users asked different things for the interface looking. --------- if you like to you system have background like those exist on mac background look like stripes,but also to work on mac style [different background for the text(blue) from the background of the folder(gray)] then its possible via changed many parameters on internal microsoft code parameters plus modifying the visual style,plus many other things , but it was and is extreme difficult to be made and to be finish[its 1 year work only the modifications of code, as i have used the images from my visual styles i made on past for vista] , but please dont ask me how i did or when it finish or if i succeed to finish it. have a look to my screenshots http://zeusosx.deviantart.com/art/WINDOWS-...USosX-141088122 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
nuker073 Опубликовано 17 сентября, 2010 Жалоба Поделиться Опубликовано 17 сентября, 2010 не знаю писали или нет, в ini файле код типа 0x000000 в инете очень просто найти hex коды типа #ff0000 например пишем в яндексе "коды цвета" и появляется яндексовский колор пикер с жёлтым цветом яндекса #ffcc00 по умолчанию чтобы цвет в ini соответствовал нужно записать так 0x00ccff не полностью перевернуть а по два символа #ffdab9=>0xb9daff у меня winxp sp3 Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Гость genius Опубликовано 21 декабря, 2010 Жалоба Поделиться Опубликовано 21 декабря, 2010 Tom Kruz Насколько я знаю, нельзя менять фон в папке в Windows XP. Можно, через ActiveX и настройки папок) ! Предупреждение: На дату цитируемого поста не судьба посмотреть? Ловите пряник. DJFlint Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
RomanL Опубликовано 17 февраля, 2011 Жалоба Поделиться Опубликовано 17 февраля, 2011 Windows XP Папка отображается в режиме не значки а таблица. Я меняю столбцы т.е. имя, размер, тип и т.д. Как применить эти изменения ко всем вложенным папкам? Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
NatM Опубликовано 17 февраля, 2011 Жалоба Поделиться Опубликовано 17 февраля, 2011 @RomanL, Сервис -> Свойства папки -> Вид -> Применить ко всем папкам Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
RomanL Опубликовано 17 февраля, 2011 Жалоба Поделиться Опубликовано 17 февраля, 2011 NatM, это абсолютно ко всем папкам, а не только к вложенным. Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
NatM Опубликовано 17 февраля, 2011 Жалоба Поделиться Опубликовано 17 февраля, 2011 @RomanL, да... Я не поняла, что нужно только к вложенным. Прошу прощения. Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
RomanL Опубликовано 26 февраля, 2011 Жалоба Поделиться Опубликовано 26 февраля, 2011 Поставлю вопрос немного по другому. Windows XP Папка отображается в режиме таблица. Я меняю столбцы т.е. там где имя, размер, тип и т.д. я ставлю теги mp3-файлов. Как применить эти настройки не ко всем папкам и не к вложенным, а только к определенному типу папок (документы, фотоальбом , музыка)? Также как в Windows7. Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Riki_Tiki_Tavi Опубликовано 26 февраля, 2011 Жалоба Поделиться Опубликовано 26 февраля, 2011 FolderFon V2.7 - есть такая прога :D Спасибо) Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
Vanushka Опубликовано 14 марта, 2011 Жалоба Поделиться Опубликовано 14 марта, 2011 У меня стоит Windows XP и непонятно как в ней можно сменить белый фон в папке на какую нибудь картинку, в Windows 98, можно просто щёлкнуть правой кнопкой по пустому месту в папке и выбрать настроить вид папки и там поменять белый фон на картинку. В Windows XP ???. Но у меня стоит две операционки XP и 98. Так вот, я поменял фон в 98, а он сменился и в XP. Вот такое получилось неожиданное решение проблемы. Если у кого есть ещё какие идеи насчёт смены фона в XP пишите! :blink: только через проги. и то я когда себе поменял этот фон...задолбался быстро...не красиво получается и смотреть не приятно... тогда нужно сразу менять "Шрифт,цвет и иконки" Цитата Ссылка на комментарий Поделиться на другие сайты Поделиться
